ARC LENGTH DIMENSION
11229.1
Hi all - is there a script to dimension the length of an arc? I can use flatten curve script to flatten and calculate that way - but need to produce a bending drawing?
thanks brains trust.
11229.2 In reply to 11229.1
Hi Alex, try this - put in this script on a shortcut key:
script: /* Update angular dimension to arc length */ var crv_list = moi.geometryDatabase.getSelectedObjects().getCurves(); if ( crv_list.length == 1 ) { var dim_list = moi.geometryDatabase.getObjects().getAnnotations(); if ( dim_list.length > 0 ) { var crv = crv_list.item(0); var dim = dim_list.item( dim_list.length-1 ); dim.text = moi.ui.formatCoordinate( crv.getLength() ); } }
Then create an angular dimension on the arc, then select the arc and trigger the script, it will update the angular dimension's text to the arc's length.
11229.3
amazing.
11229.4 In reply to 11229.2
Have you a little video about this script ?
11229.5
Thanks Michael, very handy!
www.jameselliott.co.uk
