Touch navigation
11221.1
Hi Michael! You may recall several years ago I harassed you to implement touch input into Moi, and we discovered that it worked to combine zoom, pan, rotate, and roll all into one 2 finger gesture. I'm playing now with version 5 and it looks as though the option is gone from the ini. Best I can get is 2 finger zoom and rotate with 1 finger pan.
Also, I used to ask you about weather you had any plans to explore VR as a UI for Moi. I see Gravity Sketch now and can imagine moi as a similar program in VR. Are you focusing on VR at all these days?
Good to see you are still improving Moi. I'll be using V5 to design a new iPad case in the coming days and I'm excited to use it again.
Isaiah
11221.2 In reply to 11221.1
Hi Isaiah,
What is the specific ini option that you're looking for? There are some options you can set under Options > View > Rotate/Pan/Zoom options > "Multitouch options".
Sorry no, I don't have any plans for a VR version of MoI. The environment for VR is so different that it would need a completely new program design from the ground up, it's a lot more than just a "port".
