Rotate around selected element
1120.1
Hi. Let me say how much I'm enjoying using Moi. I'm a Cinema 4D user looking for an easy to use Nurbs program to add to my toolset.
Anyway does anyone know if it's possible to change the way the rotate view works. By default you rotate around the centre of the viewport. I would prefer to rotate around the selected object / element.
Talking of views, it would be quite good to be able to double click the view name to maximize the view. Just how Rhino allows you to do.
Nigel
1120.2 In reply to 1120.1
Hi and welcome to MoI.
Give this a shot. Click on the object you are interested in to select it, then click once on "reset" at the lower right side of the viewport controls. (These are invisible until you hover your mouse over them). Once you click "reset" the view zooms to fill the viewport with the selected object. Roll your mouse wheel (or use the zoom control) to pull back to a comfortable distance. Now, when orbiting, the selected object will be the center of rotation. This works even after you deselect the object.
Whew, takes longer to describe than to actually do!
1120.3 In reply to 1120.1
Hi Nigel, I'm glad that you are enjoying MoI!
There isn't any way to rotate around a point off to the side, but you can center your view and pivot around a selected object by using the "Reset" button at the bottom of the viewport.
One click on that will center the view (and the rotation pivot) around the selected objects, and if you press it a second time it will target everything, not just selected objects.
For V1 I wanted to make a more visible way to handle switching the views - doing the double-click on the corner is kind of hidden since it doesn't normally look like an actual clickable button.
The other problem with double-click is that it can require 2 steps to get to different views, like if you are in maximized top view and want to switch to maximized front view, with double-clicking you have to double-click once to return to split view, then double click a second time to maximize the other one. I wanted to make sure to be able to switch between any views with just one click, so that's another reason why I went away from that double-click method.
But I would like to add double-click as another option to maximize views in the future though.
It is possible in the current version to set up some keyboard shortcuts for switching the view, like setting up space bar to maximize the view your mouse is over, or return to split view, and also you can set stuff up to assign different views to certain keys like 1 = split, 2 = top, etc... - let me know if you would like some details on setting that up.
1120.4
Thanks guys. Yeah I had picked up that pressing the reset button centres the selection and you can then rotate around it.
Re maximizing. I've just looked up the reference and programmed the F keys to maximise each view and one to split them again. This works fine for me as this is how C4D switches windows.
Keep up the good work. I have to say that the way snapping works is very clever.
Nigel
EDITED: 14 Nov 2007 by 3DKIWI
