Multi iso script question
11194.1
Good day.
Question on this script...it has an option to do the direction u,v or both.
How do you use the both? cant seem to get it to work.
Thanks!
Message 11194.2 deleted 17 Aug 2023 by BEMFARMER
11194.3 In reply to 11194.1
Hi Matadem,
The way that this script works is it takes an initial input edges and it will step along that edge building isoparms.
If the edge is already a U or V isoparm then only one direction is going to work.
For the way that it is set up to function, "both" will only do both directions if your starting edge is not an isoparm itself like this for example:
