Assembling Exploding
11153.1
What would be the best way to explode this section for easy assembly instuctions with dimensions? Client cannot accept CADs, only PDF... need a little help if possible... lol.
11153.2 In reply to 11153.1
Hi Shamrock, a kind of quick way is select your objects then type the Tab key and then type ExplodeMove and then Enter.
The ExplodeMove command moves objects away from a central point.
11153.3 In reply to 11153.2
Beautiful, thank you kindly that helps and appreciate the quick reply.
11153.4 In reply to 11153.3
Also, is there a forum with all commands?
11153.5 In reply to 11153.4
There's a list of all built in commands in reference section of the help file:
https://moi3d.com/4.0/docs/moi_command_reference.htm
There's a section in there for commands that don't have a button in the UI:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#Additional%20commands
11153.6 In reply to 11153.5
Thank you sir,
One last thing is there a way to created multiple viewports?
11153.7 In reply to 11153.6
Hi Shamrock,
You can have 4 viewports visible at once using the "Split" option on the bottom toolbar:
11153.8 In reply to 11153.7
Understood Michael
is there a way to viewport mutliple views for PDF
I would like to set up as 3d view elevation view, section view and plan views all in one PDF. I can in autocad but if i can do in MOi id prefer that instead
Thank u.
EDITED: 19 Jul 2023 by SHAMROCK
11153.9 In reply to 11153.8
Hi Shamrock,
There isn't currently a built in way for that but there is a plugin for generating curves for 4 views then you can export that.
The plug-in is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
