Hi Moi3dFan,
> I am generally interested in the name of this container that appears on the menu button to find its properties.
The menu button should be a <moI:CommandMenuButtton> element with a menu="" attribute which would contain the name of the .htm file for the menu.
> And I would like to understand the name of this rectangular area where the white arrow is located, in order
> to make it not on top of the button, but along the bottom edge
That's called a menu launcher, it's a little window that is shown by a <moi:CommandMenuButton> when the mouse moves over the button.
There isn't currently any way to make it launch downwards except they will go downwards if they are inside a UIPanel where the UIPanel has dock="top".
But instead of using a <moi:CommandMenuButton> you could instead use your own custom made button that would show the menu by calling:
moi.ui.showMenu( Url, ParentElement LaunchSide, LaunchDir );
LaunchSide is 0 to 3, LaunchDir is 0 or 1.
LaunchSide 0 = use top connector, LaunchDir = 0 expand to right, LaunchDir = 1 expand to left.
LaunchSide 1 = use left connector, LaunchDir = 0 expand down, LaunchDir = 1 expand up.
LaunchSide 2 = use bottom connector, LaunchDir = 0 expand right, LaunchDir = 1 expand left.
LaunchSide 3 = use right connector, LaunchDir = 0 expand down, LaunchDir = 1 expand up.
