Search in a Shortcut keys window
11136.1
Is it possible to have a Search option in a window as in the Subject?
I have so many shortcuts, very useful that some time I forget about of them and it is a little time consuming process to find the one I search.
By a key word would be a great help.
Thank you,
Marek
11136.2 In reply to 11136.1
Hi Marek, one way you can do that right now is to open up the moi.ini file which is a text file where your shortcut keys are stored.
If you go to Options > General > "Edit .ini file" button, the moi.ini file will open up in a text editor and you can use the search function of the text editor to search it.
11136.3 In reply to 11136.2
I know that, but I thought about something accessible directly in that window.
Marek
11136.4 In reply to 11136.3
Hi Marek,
That would be good to have but it would also take quite a lot of work to implement it.
Meanwhile using a text editor is not very difficult and effective already.
So it's kind of difficult to justify investing the effort required for making a built in version.
11136.5 In reply to 11136.4
OK, Michael,
Some times your response is quick with a solution and some times it requires a lot, wasn't sure about which case is it.
Thank you anyway.
Marek
