Hi Sven, so instead of trying to build a little planar fragment to boolean with, it would probably be better to edit curves and build just one large planar surface in one go.
You can convert the edges of the current planar piece into curves by selecting them and using Ctrl+C Ctrl+V copy/paste.
Then you would delete the planar surface and edit the curves using Edit > Trim to cut them with your new arc then use one Construct > Planar to make the full new planar shape.
One thing to note though is that your new arc does not quite align to the existing arc, the new arc ends here:
While your existing shape has a juncture between a line and an arc right here:
So that is going to make for a pretty small piece of a line in this area:
