Hi RayCAD1962,
I am a two years user of MOI. Before I used Solidworks and on the early days of using MOI I started to miss constraints! However, as time went by I realized more and more the philosophy behind creation of MOI. Currently I think there were several key points in the mind of it's creator and one of them is to provoke smart thinking! I realized "smart thinking" is part of MOI and that is one more reason which makes MOI more lovely. My little advice for you: try to adopt this "smart thinking" and you will begin to see that you do not really needed those fancy constraints!
Finally, if you face some examples you think they could be solved with constraints, step forth and share your challenge! I am sure good folks here are able to provide you a solution; MOI way!
And Yes as Frenchy mentioned you can use Onshape, I used Onshape to create some boundary faces/ fill faces MOI currently cannot -to create some seamless faces- and these are the features I would be super happy to see in upcoming versions of MOI but I trust @Michael and his vision. :-)
- Psygorn
