Is it possible to get text font type info?
11110.1
Good day.
If I have added multiple text in a drawing.
Is there a way to known which font type I have used earlier?
Tnx.
11110.2 In reply to 11110.1
Hi Matadem,
Was it model geometry text using Draw solid > Text? Or was it annotation text using Dim > Text ?
11110.3 In reply to 11110.2
From draw solid text.
11110.4 In reply to 11110.3
Hi Matadem, for Draw Solid > Text , if you have some of the output from Draw Solid > Text and it hasn't been modified either by moving or by booleans etc... then the font will be on a history record which you can view by selecting a letter and using this script:
var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length != 1 ) { moi.ui.alert( 'error, just one object should be selected' ); } else { moi.ui.alert( objs.item(0).getHistoryData() ); }
But if it has been edited there isn't any way to retrieve the original font information, sorry.
11110.5 In reply to 11110.4
I've been missing this for a long time.
Thank you Michael
11110.6 In reply to 11110.5
Remembering the font that was used has been a perennial problem or me. So, I have gotten into the habit of immediately naming the text object set and including the font name and size, etc. as part of the name. Otherwise, my brain lets the font name disappear into the empty regions of the netherworld.
And, it doesn't take long to disappear, either.
11110.7 In reply to 11110.6
Hi
I modified the "text" command a bit.
So It will assign "Text+Size+Bold+Italic" as the text objects name automatically .
Like this: "MoI_Arial_10_Bold_Italic"
* "Bold" and "Italic" are displayed only when they are used.
Replace MoI's original text.js file with this one.(+backup first) :)
11110.8 In reply to 11110.7
Cool!
Thanx!
