Revolve Problem
All  1-3  4-8
1111.4 In reply to 1111.3
Below is what I have made :
Regards,
Lish
1111.5 In reply to 1111.4
When I created the fixture, I got a problem when create a circle.
Here is the case :
I want to create circle with Diameter = 6.7 mm
In MoI I must input the circle dimension as Radius, so I must do this 6.7 / 2. It will take a long time for me if in my project I have many different circle.
I hope you can increase likes :
1. We can input formula in the dimension dialog
2. or we can input diameter dimension
Thank You !
Regards,
Lish
1111.6 In reply to 1111.5
Hi Lish, when you create a circle, you should see the label that says Radius: has a little arrow on it:
If you move your mouse over that label, you should see it kind of highlight like this:
If you then click on it, it will switch it to diameter mode instead of radius mode, so then you can type in the diameter instead of the radius:
That should make it easier for you to enter the diameter without doing any extra calculations. In the future I do want to support math expressions in those entry boxes as well.
It looks like your fixture has turned out well!
1111.7 In reply to 1111.6
Michael....
I see now. I have also read MoI command ref 2 a gain under "circle".
Regards,
Lish
1111.8 In reply to 1111.7
Hi Lish, I have been able to track down the bug that was preventing the revolve from working in your first example.
I've fixed it up so it will work properly in the next release.
Thanks for posting the .3dm model file, it really helps a lot to have an example file!
Show messages: All  1-3  4-8
