Identifying problem areas in joined surfaces
11069.1
I create parts that I want to be solid. After modeling for a time I realize that I have a joined surfaces instead of a solid. Is there a way with in MOI 3d or another app that will show problem areas. I have attached a model I am currently working on. Thanks rtell
11069.2 In reply to 11069.1
Hi rtell, it's good to set up a shortcut key to highlight "naked edges" which are edges that only belong to one face instead of being joined between 2 faces.
Those are the spots that need to be filled in to make a solid.
Check out here for how to set up the shortcut key:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
11069.3 In reply to 11069.1
Seems you have some big and little holes in your model to fill for make a solid! ;)
11069.4 In reply to 11069.1
So in your case here it's the bottom area and 2 other places:
The bottom isn't quite all on one plane, it would probably be good to cut off a small amount with a line to get the end all on one plane.
11069.5 In reply to 11069.1
Here is the front part made into a solid now.
For the back part the naked edges are very short so it's more difficult to get at them.
11069.6 In reply to 11069.1
Here's the other piece as a solid now too.
EDITED: 18 Apr 2023 by MICHAEL GIBSON
11069.7 In reply to 11069.2
Michael
Thanks! getting that shortcut key set up right now. Only been using MOI for 15 yrs. guess there's more to be learned....
Bob
