Is there a way to chamfer this? parallel lines?
11065.1
Good day.
I am working on something here but I cannot chamfer this...file attached. bot sides.
Also if I have a line at a certain angle and I want to make another line a distance away is there a way to draw at the same angle? parallel?
Thank you!
11065.2 In reply to 11065.1
Hi Matadem,
It seems to be working ok for me over here. What distance are you using?
For example here with 0.2mm:
Transform > Copy or Construct > Offset can be good for creating a new parallel line somewhere else.
You can also use it in drawing by making a construction line. You do that by pressing and holding down the mouse button and dragging with the mouse button still held down while you are in a drawing command. After you have placed a construction line a little marker will appear and if you click and hold on that a menu will pop up and allow you to do some other things like relocate the construction line somewhere else.
Here's what it it looks like:
