Hi NaN, re: Macro error message - looking at the error it kind of looks like the macro code is assuming that the node editor is installed in the appdata folder instead of in the ui folder.
On Mac the appdata folder is at "~/Library/Application Support/Moi", note that the Library folder is hidden by default, you can show it by holding down Shift+Cmd+. (period), or from the menu use Go > Go to Folder
On Windows open the Start menu and type %AppData%\Moi and push Enter, which will expand to something like C:\Users\<Your user name>l\AppData\Roaming\Moi
It's actually generally better to install stuff in the appdata folder since it's a centralized location outside of any one version's app bundle, so new versions will find things there without needing to copy files into each new version's individual .app bundle.
So put it in a folder like: ~/Library/Application Support/Moi/nodeeditor , and then for the launching script on a shortcut key you'll need to have moi://appdata at the start of the URL like this:
script: moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
If that solves it let me know, I'll update the wiki. Probably the wiki install information is from Moi version 3 which was before there was appdata folder support.
