Hi Moi3D users, I have this question? I recently bought Rhino 7 and it has this one function that will not work on my older laptop.
It is the smooth to flat command that toggle's the subD from mesh to nurbs. I can save these same models to a thumb drive and load them into Moi. Running the subDscripts from Moi3D and they work perfectly, and toggle from smooth to flat, poly to nurbs.
Is the code that Moi3D uses for the scripts compatible with Rhino 7. In all my reading and testing. This problem is due to a driver problem. And when an older computer can't get the most recent drivers your stuck. So far this is the only function that I have found that will not work. I also have found that this function would be so nice to have.
Sure seems like maybe a script from Moi might be able to create a workaround. I definitely plan on getting a new desktop pc to run Rhino, But at the moment its working quite well. But if I could use that Catmull clark subD script in Rhino I think I could possibly toggle that smooth to flat function. Not completely sure but thought I would ask. Thanks for any ideas. p.s. I did read that a couple of users were having this same problem. One guy even had a very new computer. He switched the graphics drivers and that fixed it. Tempted to see if a moi script will load into Rhino.
