Nodeditor Gears
All  1  2-4
11007.2 In reply to 11007.1
Hi Barry,
This is what I use to record variables to a log within the Node Editor. It writes to a file, but is not accessible until exiting the node editor.
Wayne
datapop = moi.filesystem.openFileStream('c:\\temp\\datapop.txt', 'w');
// Usage;
for (var i = 0; i < 10; i++) {
datapop.writeLine("Title " + i);
// Exit node editor to view results.
11007.3 In reply to 11007.2
Hi Wayne,
thanks for the code but how do I implement it.
Barry
11007.4 In reply to 11007.3
Hi Barry,
Create or verify this directory exists on your PC:
'c:\temp'
Here is a simple node to record the XYZ values of points.
Save this file as '_PointDetails.js' in the ext file of the node editor.
Start the node editor and load the PointDetails node that was just registered.
Attach a node with a point array output.
Run the node. (No output node required.)
Exit the node editor and exit MoI3d.
Look in the directory for the file 'c:\temp\datapop.txt'. It should be populated with the points detail.
Wayne
(function () {
   var datapop = moi.filesystem.openFileStream('c:\\temp\\datapop.txt', 'w');
	function PointDetails() {
        this.boxcolor = "#F05";
        this.addInput("Pts", "pointarray");
		this.addOutput("", "pointarray");
	PointDetails.title = "PointDetails";
	PointDetails.prototype.onExecute = function () {
		if (!this.isInputConnected(0)) {
			this.local.errMsg = 'No Data Connection!';
			return;
		this.boxcolor = "#0F5"
		var ptArray = new pointArray(false);
		var i = 0,
			pt = 0,
			inp = this.getInputData(0, new pointArray());
		for (i = 0; i < inp.getLength(); i++) {
			pt = inp.getElement(i);
			x1 = pt.data[0];
			y1 = pt.data[1];
			z1 = pt.data[2];
            datapop.writeLine("X " + x1 +" Y " + y1 +" Z " + z1);
			ptArray.push(x1, y1, z1, 0, 0, 0, 1);
        this.setOutputData(0, ptArray);
	LiteGraph.registerNodeType("WidgetSample/PointDetails", PointDetails)
Show messages: All  1  2-4
