isometric view
Tony77
21 Feb 2023 (1 of 3)
10994.1
Greetings,
is there a way with moi to have an isometric view in 3d view of an object?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
21 Feb 2023 (2 of 3)
10994.2
In reply to
10994.1
Hi Tony,
Yes, you can turn off perspective for the 3D view by a setting under Options > View > "3D view projection", set it to 3D view projection: Parallel.
You can also set up a keyboard shortcut that will set it to a parallel projection and also set the view angle to an Isometric or Dimetric view:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1917.35
You can also set the view direction angles under Options > View > "3D view angles".
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Tony77
21 Feb 2023 (3 of 3)
10994.3
In reply to
10994.2
Thanks so much Michael ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
