Romansco fractal script !?
10988.1
Is there a script which is helpful to create fractal like patterns / objects like
we know from the amazing romanesco shapes ? Or is there any available
tool around to experiment with ?
10988.2 In reply to 10988.1
Hi Tom, related thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.274
You might try searching on the web for "L-system" or "Lindenmayer system" tools.
10988.3 In reply to 10988.1
You also might try experimenting some with MoI's circular array command, applying some vertical and radial stepping.
For example starting with this:
Then a circular array with some vertical and radial stepping used:
Scale array used ( http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109 ):
Circular array applied again:
10988.4
Thank you Michael, I have used Array so far only for simple radial
multiplication and not considered using it in the way you demon-
strated - very good !
