Hi Tgoy,
You did not post the specific STL file that you wanted to convert to a "Nurbs solid".
I used a fairly simple STL for a mount for a 3M respirator cartridge, HEPA + Organic, filter + activated carbon, to a fan. (About 155 kb)
(The STL imported to MoI would be about 75,000 kb, a huge amout of overhead.)
It is just a flat slab (2 planar slab surfaces) with a few round holes, plus a cylindrical "nipple" for the cartridge.
Imported the STL to MeshLab, and saved as .OBJ.
Used ImportOBJ script to get the .OBJ file into MoI. (Did not try the OBJtoEDM script.) (About 450 kb) It is a large number of triangular faces with edges, mostly planar.
Then did a couple of hundred or so of MoI geometry commands to (begin to) get a NURBS solid. (Did not finish) It was a lot of work...
It might be easier to just start from scratch, or trace outline images...
It would have been helpful to have a script to get the perimeter of a planar mesh of triangular surface (edges).
This would not help for a 3D "dolphin" mesh.
