Surface render doesn't follow shallow curve
10950.1
I have run into an issue where the surface of a curved plane of an extruded shape doesn't seamless render Elon the curve of the edge, but looks "polygon"-ish and doesn't confirm to the actual edges.
Is there a setting or something that can be done to make the rendered/displayed surface not "jump" or "misalign" to the actual edge?
This seems to be a display/viewing issue on the screen, and not in the actual geometry of the object.
10950.2 In reply to 10950.1
Hi Lestatdelc, that's just a display artifact that should be ignored.
There is a setting under Options > View > Meshing parameters > "Mesh angle" that you can tighten up to reduce it but I don't recommend that because it will greatly increase mesh density in other areas and can bog things down when you have larger models.
More information here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10580.2
10950.3 In reply to 10950.2
Once again you demonstrate why I love using this application. The quick, and responsive reply to a user issue.
Thank you.
p.s. while it was a display artifact it was actually causing some objects to get "lost" in the "faceted" surface.
