New Algorithm for Contours
10898.2 In reply to 10898.1
Hi Brian, currently MoI can convert a subdivision surface into NURBS by using the converter located under the SubD tab at SubD > Create > "From file".
But once converted it's a NURBS surface in MoI. So an algorithm that is meant to be used for export processing on a sub-d surface is not really applicable to MoI.
10898.3 In reply to 10898.2
Thank you Michael
