Hi Teddy, thanks for sending the spindump.
So it looks like it is stuck inside some operating system functions for listing the available fonts. From searching on some of the OS functions I've seen some reports of similar kinds of behavior in other apps when there is a corrupted font file.
You might try doing this and see if there is any info in the system log that mentions problems with a particular font:
quote:
Open Console (Applications/Utilities)
In the Console window type "font" or a font name in the Filter field.
You should see messages that are font related. You may have a corrupted font.
It's probably ok after it has hit some kind of timeout and set up a font cache that is then getting used after that.
Also if you have a really enormous number of fonts that may be slowing down launch time even with a font cache being used.
Anyway, sounds like you are running ok now though? It would probably be good to get rid of any corrupted font file though because it's likely to happen again with new versions.
