Panel lines
ulisses
7 Oct 2022 (1 of 5)
10875.1
Hello,
I need to add subtle panel lines to a solid.
I'm drawing a line, adding an offset, close it, project in the surface and extrude, then boolean -> difference.
Is there a better way of doing it?
Tks,
Ulisses
EDITED: 7 Oct 2022 by ULISSES
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Phiro
7 Oct 2022 (2 of 5)
10875.2
Better or not, you could use a sweep using a projected curve and a shape -square, circle (etc.) next boolean substract.
It's easier if your curves is on a 3d path (not planar), because offset is not usable in this case.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
ulisses
7 Oct 2022 (3 of 5)
10875.3
In reply to
10875.2
Great Phiro, I will try sweep. Tks.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
7 Oct 2022 (4 of 5)
10875.4
In reply to
10875.3
For smaller closed shapes like the left and right in your image there is the inset command which has a “groove” option.
For a large panel slice like your middle arrow, probably need to jump through the hoops as already described
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
ulisses
7 Oct 2022 (5 of 5)
10875.5
In reply to
10875.4
Thanks for all the tips!
I will try the inset + groove, I'm starting to get some results.
Ulisses
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
