Weird behavior of a non-solid object
10830.1
I tried to created an interesting object with two halves of a cylinder but I couldn't do chamfer and then I accidentally faced a problem: these halves had different behaviors. While the first one was doing well the second had troubles and couldn't chamfer itself. I needed to implement some sweep and loft tools maybe because of them the mesh goes crazy. I can use the nice one just fine but I really want to know what the problem is
The nature of your top and bottom surfaces are different.
I have no problem with any!
I close each by a Plane
Union each = Solid
Chamfer 0.2
If you don't want a solid kill faces that you don't want...
Message 10830.4 deleted 27 Aug 2022 by INCOLER
10830.5 In reply to 10830.2
Thanks, now I understand
10830.6 In reply to 10830.1
Hi Incoler,
It's probably a bug, I've put it on my list to investigate.
Thanks, - Michael
