Enhancement Request : Moi Short Cut Description
All  1  2-5
1080.2 In reply to 1080.1
Hi Lish, it is possible to add a comment to the beginning part of the script. That would probably do the job for you.
To do that, put your comment inside of /* */ characters just after the script: label, see this post for some more detailed information and an example: http://moi3d.com/forum/index.php?webtag=MOI&msg=1022.13
1080.3 In reply to 1080.2
Thanks for your tips Michael,
Another ER that I want is ability to thicken a surface.
Regards,
Lish
1080.4 In reply to 1080.3
Hi Lish, use Construct / Offset / Shell for that one. When applied to a solid Shell will give a wall thickness to the solid, and when applied to a surface Shell will thicken it into a solid slab.
Check out the command reference here: http://moi3d.com/beta/moi_command_reference2.zip under Shell for some screenshot examples.
Hope that helps!
1080.5 In reply to 1080.4
I see now, I think I must read all of MoI help file / command reference :)
Thank`s Michael...
Regards,
Lish
Show messages: All  1  2-5
