Problems with "size" changing
All  1  2-3
1077.2 In reply to 1077.1
Hi Pozero, that sounds like some kind of "feature" of Poser's OBJ import. When you export from MoI, MoI will not scale different objects by different amounts.
Somehow on import into Poser they must be scaling it to try and make each object appear at a kind of default size.
That's bad because as you have seen it will destroy the proportions between different objects that you import.
Maybe there is some way to turn this off in Poser? I'm afraid I don't know Poser well enough to help you with that, you'll probably need to ask this one in a Poser forum.
1077.3 In reply to 1077.2
Yes....it's probably problems inside Poser. I''ll try to ask Poser people :-) Thanks
Show messages: All  1  2-3
