I experimented with the objects and flow for a while.
The red line is not quite parallel with the center axis of the object.
EDIT: The next sentence is false:
Using a center axis does not seem to make any difference to the Flow, as far as I can tell.
After trimming the external parts of a new center axis, as well as trimming the target curve,
Flow begins the flowed object parallel to the xy plane, but then twists the flowed object in excess of 90 degrees.
I wonder what the rotation frame of the spiral target curve is, and if there is another way to form the target curve, with "horizontal" rotation frame?
How about twisting the initial object, in excess of 90 degrees, +90+, or -90+, before the flow?
Can the MoI properties of tangents and derivatives, etc., of a curve be used to investigate the rotation frame(s) of the spiral target curve?
