Transformer stack
All  1  2
1075.2 In reply to 1075.1
Hi adx, that's really cool, I am glad you were up and running so quickly... 15 minutes!
Another thing you may be interested in for sectioning is the ability to boolean a solid with just a line segment (or actually any flat curve).
For example here I have a solid and I have drawn a line segment across it that divides it:
Now you can select the solid, run Construct / Boolean / Difference, and select the line segment as the cutting object. This will divide the solid into 2 pieces, you can then delete the piece you don't want:
You can also use Boolean intersection to create a sectional slice. For instance here I selected the solid, ran Construct / Boolean / Intersection, and then selected the line - this creates this slice:
Show messages: All  1  2
