Hello, I can try the nodeeditor, thank you for suggesting that.
This is the equation I came up with for producing refracted line
And here's the GLSL code that could do just that, I need to look into MoI scripting.
GLSL code:
vec3 refract(float n_trans, vec3 incident, vec3 normal)
// Scale normal (assuming normal is an unit vector)
normal *= dot(incident, normal);
// Preserve incident vector length as squared value
float sq_length = dot(incident, incident);
// Scale incident vector tangentially to normal,
// by transition refraction index (eg. air/glass=1/1.52)
incident = n_trans*(incident-normal)+normal;
// Normalize length of refracted incident, to scale along sine
return -incident*rsqrt(dot(incident, incident)/sq_length);
Maybe someone could implement that.
