I'm sure this is super simple but I can't get it right!
gunter511
21 May 2022 (1 of 4)
10702.1
Hi All,
I'd like to make a solid object between the two 'planes' highlighted in yellow, using the rail:
I've tried sweeping and lofting but neither work.
Could someone please tell me the best way to do this?
Many thanks!
Gunter
EDITED: 15 Jul 2024 by GUNTER511
Loft sweep blend ?.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
21 May 2022 (2 of 4)
10702.2
In reply to
10702.1
Hi Gunter,
see attached file.
Use network then loft sides then planar bottom finally join to get solid.
Barry
Network Loft Planar.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
gunter511
21 May 2022 (3 of 4)
10702.3
In reply to
10702.2
Brilliant, thank you Barry! :)
Gunter
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
21 May 2022 (4 of 4)
10702.4
Or after the Network :)
Kill curves
Plane by 3 Points
Planar by Edges Selection
Join all for Solid
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
