Switch between dark and bright layout
10698.1
what would be the fastest way to switch between dark and bright layout? Making a copy folder of the original bright (light grey) setting and copy and past from there to the correct destination folder?
Axel
10698.2 In reply to 10698.1
To switch UI theme, perhaps a shortcut key script for version 5 beta?
10698.3 In reply to 10698.1
Hi Axel, sorry I don't quite understand the question.
First of all let me make sure - are you talking about the version 5 beta and the new "UI Theme" function?
There is an option to switch it under the Options dialog, under Options > General > "UI Theme".
But there are already dark and light themes built in and you can switch just by changing the dropdown here, you don't need to copy any files just to do a switch:
10698.4 In reply to 10698.3
thanks, I was really not aware there is a v5 beta version available and this is of course a neat feature. I will it any way.
Great, thanks,
Axel
10698.5 In reply to 10698.4
Hi Axel, yes you can get the v5 beta at https://moi3d.com/beta.htm and one of the major new functions in it is a new UI Theme mechanism.
You can switch between themes there and there is also an editor for making your own customized one.
10698.6 In reply to 10698.5
I tested it and this feature is really nice :)
thanks,
Axel
10698.7 In reply to 10698.6
...I would like to add that I really like the theme management feature. It's great to get it customized in a real-time mode and you see immediately the changes you did without trial and error and restarting MOI3D after each change :))
Cheers,
Axel
