Hi Burr, it's a limitation in MoI's PDF importer.
MoI's PDF importer will read the vector graphics paths out of the PDF file.
In your 123.pdf example file, the text is stored as text entities and not as vector paths. MoI does not try to read those in as of yet, it can be a fairly tricky area with having to deal with embedded fonts.
When you convert it with the PDF printer, it's generating vector paths for the text content instead of text entities, that's why MoI can read that version in. In Adobe Illustrator there's a command like "Text to path" that will convert it also.
