Hi MRAKGR, it's probably because your view is a perspective projection and the cuts are going to project in a straight direction along the construction plane normal.
If you want it to match better you might try setting the 3D view to a parallel projection instead of perspective. You can do that under Options > View > 3D view projection = "Parallel".
