PDF conversion to DXF in Version 4
10683.1
I have been using version 3.0 to convert 2D PDF drawings to 2D DXF files which I then copy and paste into AutoCAD Version 2022 LT for further work.
It as been pretty good so far.
Just recently purchased version 4.0 and did the same process.
I can get a DXF file produced which I open in AutoCAD but I am unable to do a Copy to File to take that drawing into the main AutoCAD drawing.
I get a message from AutoCAD saying "Copy to Clip Board Failed"
I have experimented several times with both 3.0 and 4.0 versions and only the 3.0 version will allow me to copy to clipboard.
Researching AutoCAD resources on the internet tells me it is a corrupt file or a third party application issue.
Tim (TimTab)
10683.2 In reply to 10683.1
Hi Tim, can you please post the DXF file from V3 and the equivalent DXF file from V4 so
I can try to compare them and see what might be different between them?
Also if you can post the PDF source file as well that might be good so I can also take
a look at it going through the export code.
If you want to keep them private you can e-mail them to me at moi@moi3d.com .
Also when you load the v4 DXF into AutoCAD can you please run the Audit command
in AutoCAD and see if it complains about something?
Thanks, - Michael
EDITED: 2 May 2022 by MICHAEL GIBSON
10683.3 In reply to 10683.1
Why "copy and paste" into AutoCAD LT? Why not just open the exported dxf file in AutoCAD LT? AutoCAD 2022 doesn't allow me to paste from MoI either.
10683.4 In reply to 10683.3
I do actually open the DXF file in AutoCAD. It's when I do a copy for eventual pasting from the DXF the DXF tells me the Copy to File has failed.
Even if I save it as a DWG file I still cannot Copy to File.
10683.5 In reply to 10683.4
Oh, I got you. I'm seeing that as well now that I try it that way. I saved it to a dwg, closed the file, re-opened the dwg file and was able to copy and paste it.
10683.6 In reply to 10683.5
Which version of MoI3D are you using cad-guy?
10683.7 In reply to 10683.6
V4 and V5 beta. I tried it with both.
10683.8
Just tried again with V4, just to be sure. Imported a PDF from a CAD file. Exported a dxf file. Opened the dxf in AutoCAD, saved the DWG. Opened the dwg again in AutoCAD 2021 and I can now, copy and paste.
This will be fixed in the next v5 beta. It had to do with handle values in the DIMSTYLE table getting modified.
Part of the dimensions support that was new in v4 was reading and writing dimension entities and also
DIMSTYLEs to DXF files. The fix is to make sure not to modify the DIMSTYLEs that are already in place
in the DXF template file before MoI adds any new ones.
When the handle values were updated, it caused some other piece to have an invalid reference to a dimstyle
which then triggers the copy to clipboard problem later on.
Only AutoCAD was affected and not any other programs because only AutoCAD reads in every single little
complex detail ("reactors", viewport setup blocks, dimension arrowhead blocks, etc...) out of a DXF file.
