Small dimensions
10673.1
From what I can see, the dimensions text can be inline or above.
Is it also possible to move (float) the text of small dimensions so they can be positioned more conveniently?
Thank you,
Gaston
10673.2 In reply to 10673.1
Hi Gaston,
I get around it by typing spaces before or after the <>.
That pushes the text out .
Not automatic, but convenient.
10673.3 In reply to 10673.1
Hi Gaston,
Yes the text of a dimension can be repositioned to anywhere you like.
You do that by selecting the dimension and then click Edit > "Show pts".
An edit point will appear at the text location and you can drag that point to change the text position.
If you want it to go back to being auto positioned, select the point and push Delete.
10673.4 In reply to 10673.3
Thank you Michael and Mip (VINC), both solutions work as expected.
Gaston
