Nodeditor Bundle Array ?
10671.1
the attached nod file divides a curve and places a small circle then a large circle etc on the points.
The problem I have when the circles add up to an odd number ( ie; 5 + 4 ) the bundlearray is only outputting even number of circles (8).
Any help would be appreciated.
Barry
10671.2 In reply to 10671.1
Hi Barry,
The bundle array node has a logic issue. James brought it to my attention last month. It has been corrected with a new interleave logic.
Make a copy of the current arrayExt.js node group, rename it to 'arrayExt.txt' and replace it with this one. The updated node is named bundleArray2.
Nice node design!
Wayne
EDITED: 26 Apr 2022 by WAYNEHILL5202
10671.3 In reply to 10671.2
Hi Wayne,
working fine thanks.
The idea of the node is to produce a wavy pipe that could represent a weld or use to
trim then loft or blend.
Corners not ideal tried sweep manually was better but haven't got it working in the nod.
Barry
Ps:
Got sweep working now but best if corners have small fillet.
EDITED: 26 Apr 2022 by BARRY-H
