I have a 75MB 3DM file from Rhino. I get nothing when I import it into MoI. I've tried saving in both Rhino 3.0 and and 4.0 format but get the same null result in MoI. What could be happening here?
The model was imported into Rhino as a Solidworks .sldasm file (with a collection of .sldprt files). I checked and everything ends up a block instance in Rhino. Thanks for the tip.
Hi Al, you probably already know this, but just in case - you can use explode on those block instances in Rhino to convert them into just regular objects which should then be seen by MoI's importer.
