Hi Darren,
> 1) Can fillets be edited once applied?
Nope, you need a parametric solids modeling program for that type of thing, check out something like SolidWorks, Alibre, OnShape, etc... there are many out there. MoI is focused on different qualities like simplicity of initially drawing things.
> 2) When you save a file, does it always go through the same process of opening up a save
> file dialogue and then once you've named (or copied over) the file, prompt you to set the
> number of polygons etc? Or can this be skipped, and simply hitting save will copy over your
> existing file unless you 'save as...'?
Once you have opened or saved to a .3dm file to set the current active file name then when you do a Save after that it won't prompt you.
You would only get a prompt for number of polygons if you were to save to something other than MoI's main .3dm file format which does not set the current active model file name.
