keeping two faces connected when extruding
10591.1
Hi everyone!
for a project I'd need to extrude two touching faces making so that the faces remain connected, like in this example:
(the example is made in cinema 4D)
but when i try it in MoI o obtain something like this:
is there a way to obtain a similar result like the first example in MoI?
Thanks in advance!
10591.2 In reply to 10591.1
Hi Xenon472, try using the Construct > Offset > Shell command rather than Extrude.
10591.3 In reply to 10591.1
Also, you can select the 2 faces (in top view), then select extrude and extrude downwards in the front view...
