HELP !!!!
1058.1
I cant extrude by path this one, how to connect these ?
1058.2 In reply to 1058.1
Why don't you post the 3dm Zipped?
It's more easy to answer and we can repost the file with the modification :)
Seems you must use a Sweep with 2 rails and in 2 times ;)
But without the file not easy to answer exactly :)
1058.3 In reply to 1058.2
IF U EVER USE SKETCHUP, COMMAND FOLOW ME WOULD DO THIS PROBLEM SO EASELY, BUT I WILL POST FILE JUST A FEW MOMENTS !
I NEED TO EXTRUDE SHAPE BY THE LINE AND THEN TO MIRROR IT TO GET IT ALL !
1058.4 In reply to 1058.3
even with the followme tool I suppose you must erase some intersection with the model if you have a complex path or strange form ;)
EDITED: 24 Oct 2007 by PILOU
1058.5 In reply to 1058.4
No, u dont need to erase, at least i didnt have to erase it in my work. Sketchup really has some good features ! Still i need your help people how to do this !
Maybe like this : Select the curves lines as path : Join / Offset / Select the form Sweep with 2 rails
else you must place the form with rotation at each angle and make a Loft straight
or better trace the internal straigth line for replace the Offset function if you have an complex path inclined or other ;)
here with the first method :) file 3dm linked
1058.7 In reply to 1058.2
Hi Necko - MoI does not currently do corner mitering for sweep with one rail, that is ideally what you would want there but it won't be available until version 2.0 .
Until then the easiest way is how Pilou shows, good job Pilou!
1058.8 In reply to 1058.7
Thx pilou, and can i ask something, i tryed long time ago moI and it was beta then and it is now. When ver 1 is out ???
Thx for your help people !
this problem makes me nuts cos in my mind i was comparing sketchup and Moi and i just ask my self how da *uck MoI cant do this :)
Keep on good work man !
EDITED: 25 Oct 2007 by NECKO77
1058.9 In reply to 1058.8
Hi Necko,
Not much longer, mostly just some parts of the documentation to finish up.
Re: Sketchup - don't forget that Sketchup is in version 6, and MoI is in version 1. There will still be more stuff coming for MoI in future versions.
And maybe boolean operations in GSketchup are a little less easy than in Moi ;)
Each prog has it own qualities ;)
here sketchup you can make boolean but...you must make something by hands ;)
EDITED: 25 Oct 2007 by PILOU
1058.11 In reply to 1058.10
I know that people and when u see me here and not in sketchup forum, u can bet that i like this software more !
Keep on good work and if there is anything that i can help just say !
