Lines hidden by surface
10564.1
is there an option to make lines visible that are behind surfaces? I know it is possible to turn the view to look behind the surface but that is not always feasible.
Axel
10564.2 In reply to 10564.1
Hi Axel,
Yes, there's an option for that on the View palette on the side pane. Set the checkbox for View > "Display hidden lines":
You can also find it on the Options dialog under Options > View > "Display hidden lines" checkbox.
10564.3 In reply to 10564.2
thanks a lot for your straight reply. I could bet I had the lines visible before some time ago and suspected an issue with my graphic settings.
That's a relief.
Best regards,
Axel
