making solid prism of two surfaces joined by an edge ?
10561.1
Hi Forum. I need to make solids of a bunch of above mentioned surfaces. In all cases the two surfaces have a common edge. Is there a simpler way then triangulate one side with a line, then extrude, then remove superfluous surfaces ?
Size: 104 KB, Downloaded: 25 times, Dimensions: 992x698px
10561.2 In reply to 10561.1
Hi svenster, I think the least number of steps might be:
Draw a line:
Select just that one line and run Construct > Extrude and click the button in the extrude options for "Set path" and then pick one one of the other edges as the extrude path:
That should generate just one plane. Then select the original object and the new plane and run Edit > Join to glue them together. Then follow that by running Construct > Planar to put in end caps to make it a solid.
So the only thing left over at the end with this way is the line.
10561.3 In reply to 10561.2
Thanks, that's easier than what I was doing.
Sven
10561.4 In reply to 10561.3
Hi Sven another little thing you can do is set up a shortcut key with this on it:
Extrude SetPath
Then when you press that shortcut key it will be the same as running Extrude and automatically pushing the "Set path" button in the extrude options.
10561.5 In reply to 10561.4
that's even better because I have to do a bunch times, thanks for additional suggestion.
Sven
