Extend selection of connected curves
10540.1
Maybe I forgot a basic function or couldn't find the right script. As there is the script "Extend selection of edges" there is "Extend selection of connected curves".
An example below: an "interlacing" of curves, some joined, others connected but separated, and so on.
Okay, you must be busy. So maybe in 2022! that can wait! happy new year party!
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
10540.2 In reply to 10540.1
Maybe this one select all curves joined...without certitude...tested ...seems not! :(
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
But between two 3D curves you can use Blend who connect these 2 curves! :)
10540.4 In reply to 10540.1
Hi Zooen,
Not that I'm aware of. You can select a big pile of curves and use the Edit > Join command to glue together the pieces that are touching each other end to end though.
10540.5 In reply to 10540.4
Thank's for information.
- Zooen
