Albert Karlen's Hourglass_12
 1-20  21
10536.1
Salvation!
Do you know Albert Karlen's hourglasses?
I discovered them on the site "L'air du bois" a French site on which I am registered. They are beautiful virtual objects, created with AutoCAD and maybe also with the help of fusion 360. I was more particularly interested in Hourglass 12. Could we do it with MoI3D, no doubt, but in what way?
For information, if you are registered on the site, you can download objects (carpentry, cabinetry, etc.) in many formats. The .stp format is in my opinion the one that offers the best import for MoI3D.
What is interesting about hourglass # 12 is that you can also download a .dwg file with its plans, which can be converted to .dxf to be imported into MoI3D.
So there you have it, everything in hand (or almost!) To make the Hourglass 12.
I started to realize, a little more complicated than I would have thought, but full of questions and very educational for me.
I think this hourglass could be the subject of a tutorial. Okay, that's not in my expertise. Also, I put at your disposal the file of the plans which I corrected of some defects of acute angles and alleviated of the superfluous; but you can start again from the original plans by downloading them on the very good site "the woods air". in addition, an image of my modest achievement and the original in MoI3D.
I would also like to know the method you would use to make the main part of the hourglass. It would help me to progress, even if I am satisfied with my result.
I did a bit of "Advertising" by including MoI3D in the site's software list!
On the left the hourglass by Albert Karlen - On the right the reproduction of the hourglass from Zooen
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
10536.2
Link to the website
https://www.lairdubois.fr/@albertkarlen
- Zooen
10536.3 In reply to 10536.1
One Revolve, One Sweep, One Bend...
...maybe also a Twist ...
10536.5
The upper and lower extremities were a bit more complicated to perform. As well as the junction of the interior void with the 4 spiral surfaces.
The principle of this ball hourglass is that the balls go down along the outside of the hourglass then go up by a screw at the top, then redo the path!
I mentioned difficulties encountered in correcting acute angle problems on spirals with the original Original_dwgTodxf_importToMoI3D.3dm file here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10530.1
I do not know if the two subjects could be brought together?
Good, have a good Christmas holiday, see you later!
- Zooen
A little more explicite half concept :)
By Albert Karlen
EDITED: 24 Dec 2021 by PILOU
10536.7 In reply to 10536.6
This is not the same hourglass. Albert Karlen created two different hourglasses. The one I was interested in and reproduced is the hourglass with Archimedean screw, it is hollow (here: http://moi3d.com/forum/index.php?webtag=MOI&msg=10536.5). The images seem to me to be quite self-explanatory!
- Zooen
10536.8 In reply to 10536.7
Yes, it was just for show how balls were prevent from falling during their course!
Not so evident (for me) on the previous images!
10536.9 In reply to 10536.7
Hi Zooen,
not sure if this method helps to create the spiral path you need but it does hit all the circle positions you show in the 2D.
Basically I created the Hour glass inner shape and projected the 2D connection lines onto it (front lines then back lines) joined up the results to create spiral.
Duplicated it and rotated 180 thus getting the 2 start spirals needed.
Barry
Added Final image.
EDITED: 26 Dec 2021 by BARRY-H
Size: 257.6 KB, Downloaded: 78 times, Dimensions: 462x800px
10536.10 In reply to 10536.9
Hi Barry,
Thank you for looking into the subject. It is an interesting alternative to start the creation of the main part of the hourglass. The hourglass, I reproduced it entirely (or almost) out of laziness perhaps, I took the Archimedes screw from Albert Karlen. In a classic way I used the sweeping inspired by a tutorial that I had done at the beginning of my learning of MoI3D, the realization of a telephone cable.
In the end, I will still do the Archimedes screw too. Theoretically when the balls have finished their course at the bottom of the hourglass, the Archimedes screw brings them back to their starting point at the top. But can it work? The inside of the hourglass should certainly always be filled with marbles. The balls are 8mm in diameter and the notches in the 8.4mm spirals.
- Zooen
10536.11 In reply to 10536.10
Hi Zooen,
I think the elevator screw works as shown.
The balls enter from left & right and are guide vertically maintaining the 15.5mm Centres.
This way maintaining the 2 groove circuits.
Hope this helps.
Barry
How they move ?
By gravity when the hourGlass is reversed or rotate the axe or ...?
10536.13 In reply to 10536.12
the screw rotates the hour glass is stationary.
Barry
Here is an example.
https://youtube.com/watch?v=Y712yhoaXZc&feature=share
10536.14 In reply to 10536.13
So there is an electric engine ?
10536.15 In reply to 10536.11
Hi Barry,
But yes of course! I was so focused on modeling that I didn't bother to seriously study how it worked.
Oh dear! at my age...!?!/###/!?!
Well, the screw is not an Archimedean screw. It is, as you say, an "elevator screw". The Archimedean screw is tilted (dixit Wikipedia)
Barry> the screw turns the hourglass is motionless.
In Albert Karlen's original hourglass, the screw is integral with the support (notches on the upper and lower parts of the screw). So would there still be a design problem?
But in fact, it may be a prayer wheel for an unknown deity!
- Zooen
EDITED: 27 Dec 2021 by ZOOEN
10536.16 In reply to 10536.15
Hi Zooen,
have looked at the 3D of Albert Karlen's Hourglass_12 and there's an option for section analysis so you can see the elevator screw.
It looks like the elevator screw is stationary and mounted to outer frame and the hour glass pivots around it.
So don't think it's motor driven just rotated by hand thus elevating the balls.
Hope this helps.
Barry
Ps are going to make one ?
10536.17
Hi Zooen,
You might also like to look into the more modern application of this concept, called a ball screw and used in precision locating, for example machine tools.
https://en.wikipedia.org/wiki/Ball_screw
--Larry
10536.18 In reply to 10536.16
Hi Barry,
In my opinion, the screw is integral with the support and it is the hourglass that we turn by hand. Maybe my en / fr and fr / en translations are playing tricks on me!
Here is the answer of Mr. Albert Karlen (on the site the area of the wood).
to Pilou's question: How does the Archimedean screw turn? by hand or by a motor, or simply by turning, or ...?
The screw does not turn, it is the hourglass which turns around the screw which it is integral with the support, in the state it is done manually but one can imagine adding a motor ...
- Zooen
10536.19 In reply to 10536.16
Barry,
I tried to reply to your private message, but my PM won't send (it is stuck in "outbox"). Not sure what the issue is, but thought I'd try posting here instead.
I have attached NOD file based on your's.
Is this what you needed?
EDITED: 29 Dec 2021 by JFH
10536.20 In reply to 10536.19
Hi James,
thank you works great.
I have added the option of duplicating and rotating the sweep to give a 2 start spiral.
Also an offset option of the revolved curve thus to retain the balls.
Finally boolean difference to complete it all in the Nodeditor.
Anyway again many thanks.
Barry
Happy new year.
Edit added second shape.
EDITED: 30 Dec 2021 by BARRY-H
Size: 241.5 KB, Downloaded: 74 times, Dimensions: 800x600px
Show messages:  1-20  21
