As Enscape works directly with Revit, SketchUp, Rhino, ArchiCAD & Vectorworks
I suppose you can export also from Moi in 3DM, SKP...3DS, DXF...
(not tested because I have not Enscape! :)
In other side Only the file formats; *.gltf, *.obj or *.fbx can be imported to the Custom Asset Library of Escape
so FBX can be used ;)
But...if it is possible to import models with a file format of OBJ, FBX, and GLTF. It is recommended that you import low polygon models with less than 20,000 triangles !
