Ctrl C Ctrl V into Vector Graphics
10511.1
I am wondering, if it is possible to create a command that converts the selected object into SVG, place it onto the Clipboard to insert it into a Vector graphics software, such as Affinity?
Or PDF inside Affinity... (or a shortCut)
10511.3 In reply to 10511.1
Hi andras,
You can set up a shortcut key with this on it to transfer into Affinity Designer:
script: /* Copy PDF format to clipboard */ moi.geometryDatabase.copyToClipboardPDF();
You can also put an .AI version 8 file into the clipboard using this:
script: /* Copy AI format to clipboard */ moi.geometryDatabase.copyToClipboardAI();
PDF works better than AI for transfer into Affinity. For Adobe Illustrator AI format works better.
SVG output is not supported yet in MoI but I'm expecting to add it for MoI v5.
10511.4 In reply to 10511.3
Excellent!
10511.5 In reply to 10511.3
It sunds good, but I wanted to use SVG because PagePlus works well with SVG.
Could you help me with some scripting how to convert curves to SVG and create SVG file.
1. I would expect the coordinates and control points of curves could be listed,
2. I need to to turn this list into SVG syntax
3. I need to create a file on Desktop
4. I need to copy it to clipboard.
Andras
10511.6 In reply to 10511.5
Just save the .AI as SVG from Illustrator, or any other vector graphics app that let's you save from PDF/AI format to SVG?
Even Inkscape , a freebee, let's one do that...
10511.7 In reply to 10511.5
Hi Andras, sorry no it's not really feasible to write a script to do that, because it's both too complex and also there isn't quite enough information currently exposed to script to do it.
If you would like to give it a try I would suggest writing out from Moi to either an .ai or .dxf file, then you could write a program external from MoI to process the file and convert it into SVG format rather than trying to do that directly from a MoI script.
But it won't be too much longer before the v5 betas start up where there will be SVG support built in so any effort to hack it in currently will be pretty much just wasted work.
I'm not familiar with PagePlus, it looks like it is a discontinued earlier generation version of Affinity? Is there a particular reason you're using that instead of the newer Affinity line? PDF on the clipboard does work right now with Affinity.
10511.8 In reply to 10511.7
Thank you,
Under consideration :) Yes, I still use PagePlus because I have it and still useful. I can open existing files, but I cannot open them in Affinity. That's why I want to keep it.
I will test PowerPoint later too. Affinity is intuitive because it has round edge feature compare to the older Page Plus. PowerPoint has a great equation editor.
I'll ask Rhino guys if SVG to clipboard is exist.
Andras
