I've always liked using Moi but don't get to use it often as (like most of us) my modelling is mainly SubD. I had a Jerry Can I had to build for a still today which I had built as SubD but then had to add some caplsule shaped indents to it. It would be a nightmare in a standard SubD workflow but I thought I'd try Moi's new SubD import function and it was amazing, half an hour's noodling and I was done. The SubD to Nurbs conversion is miraculous, thank you MIchael.
SubD model
I made the capsules in Moi and offset them to trim a larger shape out of the jerry can. Then I offset the jerry can inwards to trim the capsules shy of the surface. Then blended between the edges to get a nice bevelled edge with ease
I put Moi's excellent mesh export back into C4d to test render for any surface irregukarities
Rich
www.loopcorp.com |
