Hull design (Supply Vessel)
10486.1
General purpose Supply Vessel 33.75m X 9.15m X 4m plans are made using MoI.
Hull curves are very basic. Only 7 of them are used (the 8th in the picture is for aft profile). MoI will "Loft" them for your
After some work curves are faired "Rebuild" and ready to be used as FRAMEs. At the origin, the are obtained using "Intersect" function.
There is 12 control points for each frame curve and they are verified individually.
Details are important to give an idea.
A view from the aft
Surface can be rebuild to verify if it is clean. This one is rebuild using "Loft" based on faired curves.
EDITED: 21 Oct 2021 by ERYON
10486.2 In reply to 10486.1
Cool!
Don't know if that can help for verify curves/Surfaces but there are inside the Free Design Spark mechanical 5.0
these functions: Minutes 1.12 --> (voir mon site pour les astuces https://moiscript.weebly.com/designspark.html )
10486.3 In reply to 10486.1
Nice work, congratulations on the final result, I hope to see other interesting projects, and
If you have time, you could make a tutorial to make the hulls.
10486.4 In reply to 10486.2
Merci Pilou.
10486.5 In reply to 10486.3
Thanks for your appreciation.
No problem for the tuto but it may require some space on the Server.
I have no idea about the rules, perhaps someone (Site admin) can clarify.
10486.6 In reply to 10486.5
We have just some few place on the Moi server!
So for the images you can use something like free https://imgbox.com (not limit except 10 megas by image! ;)
and for the files something like https://www.mediafire.com (10 Gigas free)
10486.7
Bonjour Pilou et merci pour le tuyau.
Comment faites-vous pour couvrir autant de sujets ?
10486.8 In reply to 10486.7
Vu mon âge avancé, je n'ai plus que ça à faire! ;)
10486.9 In reply to 10486.5
Hi Eryon,
Each forum user can have up to 50MB of attachments hosted directly on the server. If you post .jpg images that's enough space for quite a lot of those but things like videos will fill up that space pretty quickly. If you need more space you'll need to use some kind of file sharing service and put in links to it instead of directly uploading the files here.
10486.10 In reply to 10486.9
Thanks Michael. I think for a tuto it is fairly enough space.
Eric
10486.11 In reply to 10486.2
Bonjour Pilou,
Question bête.
- Y a-t-il une fonction qui permet de changer la couleur d'un -seul- objet sur un calque (différent de ce dernier) ?
- Existe-t-il un moyen d'arborescence pour organiser les calques en sous-calque ?
Désolé de vous embêter avec tout ça.
Cordialement
Eric.
p.s. Dans quelle région du pays êtes-vous ?
10486.12 In reply to 10486.11
Il vaut peut-être mieux poser les questions en français sur le forum francophone! ;) http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS
I don't believe there are yet some layers and arborescence system inside Moi3D!
Just Names, Colors but any selection can have any Names & Colors !
It's sufficient for tricky intricated selections who are not possible in classical layer modes! :)
10486.13 In reply to 10486.12
Thanks Pilou
