MoI under Linux! Yes! It works!
All  1  2-3
1047.2
Whoops!
Forgot to add:
This won't simply help Linux users, it'll broaden your market to users stuck with integrated graphics cards, laptops, etc. that don't support D3D9 - so regular windows users too!
I'm so damn excited, I hope my posts have been coherent. :)
1047.3 In reply to 1047.1
Hi zsouthboy, I'm glad that you have it working!
But I'm not really sure that this is going to work as a fully general solution though. The problem is that the SwiftShader DLL is a software only renderer. It just isn't able to handle a larger number of polygons, particularly with a lot of alpha blending which MoI tends to use for several things.
I gave it a test over here and the speed results were not encouraging - using just a medium complex model I got 606 milliseconds per frame using SwiftShader, compared to 49ms per frame using regular hardware rendering. This is on a system with a P4 2.4Ghz, Radeon 9600 pro.
Things are significantly sluggish with the software-only rendering, even just drawing the grid with no objects in the scene at all is pretty slow.
SwiftShader is just more oriented towards being used in games that have a low polygon count.
MoI is just not designed with a low polygon count in mind, the overall design assumes that you have a graphics card that can rasterize quite a lot of alpha-blended polygons quickly...
Show messages: All  1  2-3
