Import ???
All  1-3  4-7
1043.4 In reply to 1043.1
Hi Necko, I have fixed up one part of the problem that was preventing this PDF from being read, I have attached a 3DM version here.
But as you can see, it is upside-down so I'm going to look into a little bit more to see if I can fix that as well. For now you should be able to mirror it to fix it up.
The other thing is that I guess this PDF was probably generated through one of those PDF printer drivers? That usually creates a side effect that all curves are broken up into line segments, so just be aware of that.
1043.5 In reply to 1043.4
THX MAN, A LOOOOOOT !
This is one beautiful program !
Yes, i tryed from autocad, sketchup and it didnt work :(
I work in archicad but there i didnt have clean ver.of drawing so i tryed from Sketchup and Acad... I tryed everything, eps and pdf but it didnt work !
Now i will try to finish something what sketchup cant. This is a great modeler program and i write about this program on arhicad forum cos archicad dont have modeling capibilities, so if u trying something good, try it to connect to archicad. There is a lot of users who need easy, fast, efeective 3d modeler.
Anyway, thats my winsh !
and Michael, thank you for your time !
EDITED: 22 Oct 2007 by NECKO77
1043.6 In reply to 1043.5
Hi Necko, I have a new patch available here: http://moi3d.com/beta/Sep4_patch4.zip , this contains a fix for the PDF import problem.
To install the patch, download it and unzip it to get a new moi_lib.dll, then copy that new version over top of the older one in C:\Program Files\MoI beta Sep-4-2007\ .
After that MoI should load your PDF properly, and hopefully any others that you generate in the same way. Please let me know if you run into any other problems reading PDF files, it helps a lot when you send the file for me to test like you did here, thanks!
1043.7 In reply to 1043.6
ok, thx a lot
This is very powerfull modeling program, and simply to use !
I will use this way of import and waitnig for dwg import ! IT IS something under MUST for MoI !
REspeCt and keep in touch
EDITED: 23 Oct 2007 by NECKO77
Show messages: All  1-3  4-7
